- Valve Tick & Fluctuating Oil Pressure Guage
- clutch pedel adj.
- Rear Main Seal Help
- Carb expert needed
- rough idle when cold
- 4.9l fan shroud?
- Filter bypass...
- Timing TDC, rough idle
- Might be having to make a colorado run, ? about carburetors at altitude
- Removal of smog system
- shift points...
- Rear axle change, level of effort, cost, advice?
- One more time on timing...
- Burning Alt. bearings with shorter belt, maybe?
- When you use a truck like a truck
- 4.9 exhaust
- FI 4.9 ? revisited
- Alternator and battery
- throttle body spacer?
- DSII Just plugs in ?
- The 300 I6 is awesome! How can i make it better?
- Finally got my very own Ford!
- need help on power gains
- Intake Air/Exhaust Manifold Preheat Shroud
- Question on EFI manifolds
- Spark Plugs
- another question about headers for a 95
- Can the 300 be built torquey
- carburetor ?
- Old motor.....want to get it running
