- I love my truck
- DURASPARK: Ticking spark-like noise when engine is turned off? Erratic RPM?
- Do I have the WRONG carburetor? or wrong jets maybe?
- Intake questions?
- Summer Overheating
- Greg This ones for you
- oil pressure ?
- Block code?
- Oil in intake valleys
- Valve knocking noise on a fresh rebuilt 360!
- 390 build for having fun
- Timing off 180 degrees? Or coil problem with only 6 volts?
- keith black pistons
- Rocker Shaft Torque
- plug gap?
- Crank case vent ?
- 352 .030 Rebuild kit help
- 391 Oil pump drive shaft?
- FE 360 carb vacuum connections? help please?
- Water in oil?
- FE parts catalogs
- off-idle hesitation 360 2 bbl Motorcraft?
- EGR and Performer RPM confusion
- Parts & pieces put together
- Distributor mounting question, and spark plug wires question
- Rebuilt engine, OK to re-use my old push rods?
- 352 to 390 camshaft retention method
- wheel well exit headers?
- MSD Crank trigger?
