- Building a motor for my 71 F250 - 360 or?
- Engine noise after warm up.
- quick engine interchange question
- cam won't fit
- FROM 7000 ft DOWN TO ABOUT 1000 ft
- 390 swap
- Fresh Heads
- 68 360 questions
- Torque and sequence info needed
- 390 fe bellhousing Q
- Trouble 390
- will it be worth it
- Ignition Timing a Modified FE - SUCCESS
- Confused by ballast resistance wire
- Alt. and coil where do they belong on the FE
- 352 problem
- Questions Questions Questions
- Holley 4150
- need recommendation for header gasket
- Have a balancer quest. w/ pics
- Pushrod, Help!
- Oil capacities for 332, 360, 390 FE's
- Good FE junkyard in GA.
- FE series and 352 clarification
- Another "check" in the win column.....
- aerostar front end and a fe engine???
- What are my heads on my 390???
- Carburation questions.
- Happy Independence Day everybody!!!
