- Timing
- Will the 5-speed behind a 391FT.....
- Which tranny output seal?
- best 390 build package?
- Best cam +intake combo for 360 in F250
- Water neck interchange?
- Engine miss
- Charging system wiring?
- 428?'s
- Victor Reinz Nitroseal intake gaskets
- 428 crank
- Help! 390 smokes with adjustable rockers
- C3AE-H heads ?
- intake manifold shootout
- FE heads, freebies
- Desktop Dyno Request
- New Timing Tape?
- dieseling and run-on
- gm style HEI distributoe for Ford
- coolant flow
- motor mount kit
- Adding GM's Assembly lube to increase ZDDP
- help 390 won't run right
- FPP rockers
- Snow Performance Stage 1 Boost...maybe
- 390/C6 value?
- Pending 410
- Efi
- Shorties vs longtubes
- cam specs
