- rebuilding the 390
- 360 Fire and Fuel
- Total advance on a modified FE
- Male fitting where PCV goes in valve cover?
- 410 (428 crank) to an NP 435 - what do I need?
- whats this worth
- Possible carb issue?
- C7AE-B Heads
- fe in a 85 f150
- Wierd FE problem
- Starting FE 390 after 1 year of storage
- best exhaust setup for a 390?
- Would a 460 intake fit a 360-390 ??
- Vacuum advance can with PV switch
- Straighten me out on engine noise!
- Piston pin bushing question
- HELP! found a threaded allen head in oil pan
- whats the advantages of
- Some 391FT rebuild questions . . .
- Factory timing on a 390
- Autolite 2100 Fuel Inlet Adapter Help
- How much is too much psi?
- 71 F250 wiring problem?
- Valve covers for solid lifter 428?
- Picked up a true 390 on sale/moving day!! Barn/Field find!
- Looking for FE stroker rotatng assembly
- Crankshaft Damper
- Flex Teeth vs. Starter Teeth.
- Good Dual exhaust for FT 332?
- Max RPM
