- Might be birthing another Fe into the family!
- U3 crankshaft
- fe crank casting
- 77F250 with a 410 motor
- Kit confusion
- Low oil pressure when warm
- best points conversion kits
- Proper Size Carb
- Crane Performer Cam
- 360 pump up compression
- "Canton" oil filter adapter?
- New to the site, got LOTS of questions...
- swap 351m for 360?
- Broken Pushrod
- Port matching the intake
- Field checking a crank
- Newer 390 Grenaded :-(
- pick a cam?
- Newer 390 won't start, coolant in crankcase
- HELP with motor ID...
- Larry your box is full LOL
- 65 352
- Is the 410 the highest a 390 block will go?
- 360 intake and exaust..
- TRW Piston verification
- Cylinder head valve size difference
- FE AND FT starter ?
- Pingaling goes the poorly decked 390...
- 390 Engine potential vs. others
- installing a slip on repair sleeve on crank sleeve
