- a 428 crank
- Surprises both good and bad
- 360 and 390 ignition timing
- Replacing head Gaskets on a 76 360
- motor id and specs
- Broken Flywheel
- cheap FE headwork?
- What's the biggest cam I can put in a otherwise stock 428?
- stock compression ratio on a 428?
- FE tranny
- 360 to 390?
- 428 takes a LONG time to warm up
- what type of oil do you run in your FE?
- how hard is it to install a cam?
- '71 390 miss
- Black Ford Motorsport vavle covers????
- 360 cam
- 391 FT
- Weak Head Lights in 75 F150
- Stupid question
- how to identify a 410
- 390 build
- 428 FE
- Need Weight For Drag 2000 71-F250
- lifter life
- put the new carb on today....
- 2 questions and a helpful tip!
- 2bbl to 4bbl
- 390 heads C3AE-G what are they
- 390 FE Heads
