- Replacing 390 pistons
- hydro lifter styles??
- checking my 390
- intake id/value?
- Anyone know details about this carb?
- dui/hei distributor
- Casting number id
- MILLING THE HEADS
- cam grind ..can you help Rat Smoker..
- 360 Troubles
- intake ports in head burn?
- pcv blockoff?
- Best Gaskets
- smoking 390
- another cam question
- carb problems???
- 390 A/C Compressors
- HOOOTTTTTT 360
- 1300 HP
- What heads are these, and how good are they for
- high volume or high volume/pressure?
- question about a holley carb
- Taking the ugly drag truck to.....
- How much oil do you guys use in a 390?
- my 360 hesitates
- Flat spot when accelerating from 75mph
- I can't drive 25! Help!
- freeze plugs
- used 460
- What engine do I have?
