- Weiand intake manifold
- older iron heads
- I need some advice
- A quick question for the FE gurus
- 390 rear main seal?
- checkin in/curious about 390 ideas
- Valves
- cams and compression ratio
- advertise
- no fire any idea's
- Roller Rocker Question?
- 390 rod length???
- carb spacer??
- intake manifold
- dizzy about the DUI
- c6 to aod
- 390 EFI or Fuel Injected
- Scouder and Ratsmoker
- Pushrods?
- Motor Update, DDyno Request
- Block ID
- 3 7/8" sroke?
- Bent pushrods-HOW DID IT HAPPEN?
- dizzy/ignition ?'s.
- Anyone need a 360?
- Crane cams for 352......
- removing a frozen stud
- Camshaft Bearing Removal & Replacement
- headers and exhaust size
- Installing a Cam
