- Identification problems
- throttle linkage
- Leaking head gasket
- miss or slight vibration 68 f100 360 help
- 390 in a 67 f-250
- 390 Hi Po build or 428 hi po build?
- spark plug fireing order for a 360
- Fuel Requirements for New Motor?
- FE ID (external appearance)
- Leaking intake manifold at rear margin...
- Tailgate effects on MPG thoughts...
- 428 Canadian CJ heads....
- What is this engine?
- what to do????
- what you think Rebuild time?
- Pin hole in header!!
- Harmonic Balancer
- DSC link ???
- FE design questions...
- Exhaust Manifolds
- Cam Question
- I'm back. Acceleration issues.
- bigger problems than I expected(I cant catch a break)
- Getting ready to build up a 390
- crank case evacuation possible w/stock exhuast?
- adjusting timing curve on stock duraspark
- Mis-match ports intake/head
- Mystery 360?
- seting dist.
- Erson's?
