- 390 Head Gasket Question
- What about changing the firing order???
- Header Question
- 511 finished at last... Pics in gallery.
- Engine ID problem
- 390 Truck engine same as car engine.
- Exhaust ports in Intake Manifold??
- GD timing messed up 70 390
- Calculating compression ratio...
- 390 im looking at
- running the valves on a 360
- oil pressure ???
- Not a 360? 351/400?
- Single plane intake question
- 390 intake question
- No Compression on #1 cylinder
- Well I did it Anyway??
- FE446 recovery plan.
- To port or not to port
- carb question
- Fuel Injection Installation
- FE Nationals web page coming soon...
- Engine ID
- compression ratio
- rocker shaft removal?
- H-pipe placement on a F.E.
- 1970 f100 throttle bracket
- 352?
- Stumped
- what aftermarket ignition?
