- Head torque specs?
- Offenhauser intakes
- 390 install?
- 330 radiator foaming
- FEs- known to crack in oil gallerys ??
- 390 barely turns over when hot
- 360 cid HP
- Timing Chain Question
- fact or fiction... "until its warm it runs like.."
- Help me - Water everywhere
- Engine Builder Recommendation Needed
- 390 Rad cap
- Holley 670 on FE360 finally working good
- 360 build up help
- exaust manifold leak, risky?
- MSD dizzy gear and stock gear not the same!!!
- Ft 361
- 390 block
- Piston pin rod bearing gone.
- Gas pedal mod for your F-series.
- 352 harmonic balancer
- 4bbl manifold from 66 Galaxie on 73-76 360/390?
- 352 intake disassembly
- Where is the torque converter drain bolt? Ford 360 w/ c6?
- what to do with my 410? (heads and such)
- Help...FE intake swap problems
- whats the right gap?
- Fuel Fouled?
- Some nostalgic pictures from Russ...
- Vac and Timing?
