- Oiling Mods..For the 428CJ ??
- 390 running problem
- any 390s with a steel crank
- starter help
- 352 motor idle great runs poor
- Help installing cam
- What should the dwell be for a 390?
- More Oil Pressure ?'s
- 360 not runnin right.
- How can ya tell?
- 76 390
- A new way to pull weeds
- 390 Clutch Size
- How can I tell if I wiped a cam lobe?
- Oil dripping from back of motor
- #4 plug knocked loose by valve?
- valve guides!
- Are flat tappet camshaft failures commmon....
- elec. dist. on 68 360.
- 3" single or 2 1/2" dual exhaust...??
- Edelbrock 600 carb
- o/t what do you think?
- engine problems?
- clutch kit for 360 work with 390 also ?
- 390 build...maybe??
- What will my gas mileage be???
- mini starter and headers...........anyone..??
- propane conversion
- bad miss at idle
- Where to find rear sump pickup for FE???
