- 352 to 390 FE conversion
- Stalled out and now no start
- FEs are like a box of chocolates...
- $3600 For Shortblock ?
- Carb question
- Pull intake again? wtf!
- The 48 cylinder project
- First startup after reb.
- Starting an old 390
- which mufflers?
- Clip Removal ?
- Sponsors on this website?
- fe oil pan problems
- PO Boy Flow Bench..
- wiring help...please
- 76' 390 and 69' 360 = same trans bolt pattern?
- 390 header question
- Reasonably cheep roller rocker setup.
- comp cams 260H
- oil pan removel on 390
- what would you do?
- 360
- Valves all different heights
- 0 oil pressure durring engine break in
- I am not on here very much.
- 1976 390 Redline Question
- Camshaft dowel pin Help/ answers?
- 390 FE intake gasket replacement
- 352 ? will it idle
- Ford C8ae-h and C7ae -a
