- Some 391FT rebuild questions . . .
- Factory timing on a 390
- Autolite 2100 Fuel Inlet Adapter Help
- How much is too much psi?
- 71 F250 wiring problem?
- Valve covers for solid lifter 428?
- Picked up a true 390 on sale/moving day!! Barn/Field find!
- Looking for FE stroker rotatng assembly
- Crankshaft Damper
- Flex Teeth vs. Starter Teeth.
- Good Dual exhaust for FT 332?
- Max RPM
- Building a motor for my 71 F250 - 360 or?
- Engine noise after warm up.
- quick engine interchange question
- cam won't fit
- FROM 7000 ft DOWN TO ABOUT 1000 ft
- 390 swap
- Fresh Heads
- 68 360 questions
- Torque and sequence info needed
- 390 fe bellhousing Q
- Trouble 390
- will it be worth it
- Ignition Timing a Modified FE - SUCCESS
- Confused by ballast resistance wire
- Alt. and coil where do they belong on the FE
- 352 problem
- Questions Questions Questions
