- HO oil pump ??
- Fixing Chronic 390 Exhaust Manifold Leak
- FE 360 vacuum advance troubles
- How big can you get a 390?
- 1974 Ford 360 help
- valley pan
- Cam help
- Gasket material
- deleting threads?
- 360 spark on only 3
- 390 high comp?
- 428 FE
- compression ratio help
- C3AE-G
- 268H at elevation
- Pistons
- Intake Suggestions?
- Thoughts on a 360 problem
- Bored over 390 or 428?
- COMP 268H Break-in?
- 360 to 390
- 390 or not?
- Rebuilding my 390
- Breaking in newly remanufactured engine...is a little smoke normal?
- motor choice? 360/390 or 428???
- Two questions...Three
- 390/406 build
- a serious ? 500 hp sherman tank ford gas
- Compression question with head gaskets??
- time to rebuild!
