- rattle noise @ idle
- Can I swap 96 3.8 heads onto a 95 block?
- Califonia Emissions
- Cleaning inside Plenum
- 3.8/4.2 dimensions
- What's better the 4.2 V6 or the 300 I 6?
- Engine light :/
- stripped oil drain plug???
- Freeze plug leaking
- '94 F150 problem...need help
- 96' Windstar 3.8 bogging down.
- 4.2 missing PO300 code
- towing
- 3.8 exaust control valve
- descreen and gut maf
- 3.8 throttle body cleaner problem
- whats the spline?
- 4.2 no start
- Excessive pinging (valve clatter) (Brian)
- How to include a 4.2 parts picture with message
- 3.8 help
- misfire code
- P0171,P0174 Freeze frame data
- 4.2 noob with questions
- Check Engine Lite
- 3.8 DIS oil pump driveshaft
- wierd buzzing sound under the dash.
- 98 4.2L rebuild or replace
- broken wires to IAC, suspect chased away
- just purchased a '97 F150 w/4.2L
