- Merc 5.0 V8 (Mtnr), Cylinder Misfire
- new truck or upgrade old one???...
- Recharge K&N Air Filter
- starter
- spark plugs
- butterfly valves in manifold
- 4.2L v6 conversion to 5.4L v8
- Motor is powerless
- Ticking noise after cold start
- When a tree falls on my truck, does anyone hear it?
- My SC kit update
- Started taking apart 4.2L
- flowmaster
- k&n, kinda?
- Will a 2000 3.8 swap out for a 1996 3.8?
- New exhaust questions
- magnaflow exhaust is on!!!
- miles between filter change?
- Need help!! Temp sensor
- Egr
- 98 PCV valve help
- Lean codes and wants to stall at idle. Help!
- oil leaks
- ticking noise
- Which oil to use
- What's your MPG
- Fuel Question
- Idler Puley on the belt tensioner bad! Help !
- chip question
- Throttle body
