- 2000 Ford F-150 4.2 4x4 wide band
- MAP/MAF Install Ford F-150 4.2 2000 4x4
- 4.2l v6. Yay or nay?
- Ford Newb- Pulling 97 4.2 Help and Advise Please
- Where to find parts for 97 4.2 L engine
- 98 F150 Fuse Issue V6
- What Did You Pay For Intake Gasket Replacement
- 01 f150 4.2 need help
- Electrical problem...I need help!!!
- 1998 F-150 4.2 woes......
- 06 Freestar 4.2 engine noise
- 98 4.2 F150 Fuel Rail Disconnect
- In Need Of A Catalytic Converter
- Engine Idle varies after alt. replacement
- ARGH! 3.8 playing up
- ford 4.2 V6 performance
- pcv valve??
- CHT Sensor
- Antifreeze Leaking from top of intake manifold
- transmission ideas
- 2002 E150 Rough Running
- 2005 4.2 idleing way too high
- 3.8L V6 Head Tightening Sequence
- 3.8 engine swap/tranny questions
- oil pressure gauge
- Anal Retentive idle issues
- oil filter question
- evolution/improvements of the 4.2?
- Misfire/lean running problem on 01 4.2 - help?
- slight stumble at stop
