- 4.2 V6 engine swap
- 4.2 oiling system
- 97' 4.2l V6 running rough
- Cranking but not starting,low fuel indicator on
- Super6 4.2L Stage 3 power pack
- blew a spark plug out!!
- Intake removal questions.
- Blower Motor?????
- Code P0303: What to try next?
- 05' F-150 A/C Complete kit for cheap?
- 4.6 clutch behind a 4.2l
- 4.2 Oil Pump Install
- 97 f15o 4.2
- 4.2L external coolant leak question
- A must read for all with 4.2/3.8 questions
- 05 f-150 performance parts?
- oil pressure gauge fluctuating
- time for a replacement engine..3.8, 5.0, or modular?
- 3.8 Help!!
- 4.2 issues?
- exhaust
- 4.2 v6 light ticking at idle and just above idle!
- speedo
- help!!! exact location of PCV on 02 4.2 - F150
- oxygen sensor bypass..or ?
- 97 4.2 sensor on right side of block?
- Bigger tires
- HELP 4.2 lower intake gasket leaks oil into intake
- 3.8 problem
- 2001 Ford E-150 4.2L TDC
