- Problems with my '97 F150
- Checking for vaccuum leaks.
- Oil Pressure Guage
- new 98 f150 owner, question about hydrolock
- New problem with lower intake gasket
- Rebuild or replace after intake gasket failure??
- 1997 with 4.2 gasket issue, HELP! ??Ford Tech Data Bulletin?
- 97 4.2 oil pressure gauge drops @hot idle
- 4.2l Won't start or turn over.
- Lower intake gaskets failed
- MAF sensor
- 4.2L Gasket Issues and Other Questions.
- Cold temperature starting issues...
- Seafoam
- 4.2 Cold Engine Knock or Ping
- Vapor locked Cooling System
- When was it built?
- Cpp switch removal
- Valve clatter
- Wants to Start!!!!!! please help me!!
- Oil sender switch...help!
- Do I want a piece of this?
- 2006 150 4.2 parts?
- comparison 4.2 to 300 inline 6
- rough ride
- Engine knocking
- Cam position sensor adjustment
- 4.2 missing??
- Winter Driving
- What is the oil capacity for the 4.2 in my 02 150?
