- Small Backfire??
- EGR Low Volume
- bad head gasket?
- 4.2 liter
- 4.2 2002 cranks for several seconds when warm.
- 97 F-150 Starting Problems
- Coolant leak, Hydrolock questions
- P0174 Won't Leave Me Alone!!
- 4.0 Vs. 4.2
- 4.2 swap how long?
- 4.2 to 3.8 swap done. Now shaking at low rpm.
- Maybe Coil ??
- New Motor Question 4.2 Differnce
- 2Q's - Idle & A/C
- 4.2 still lean after extensive work, help!!!
- 4.2 skipping at low rpms
- 97 F-150 4.2L V6 Starting Issue
- Pulleys
- Question about plug wires...
- Transmission fluid change
- P0401, C1230, and finally, C1096
- Engine Lite On 4.2
- Transmission trouble
- Where is WOT relay on '01 f150 4.2L?
- Blue Devil head gasket in a bottle
- Need to replace 4.2. (Years/options?)
- 4.2L redline?
- 01' 4.2 f150 camshaft upgrade
- '01 F150 4.2L blowing fuse 23, multiple codes
- Changing coolant in '05 4.2L
