- 3.8 head
- Unidentified sound
- Screeching ; A/C clutch or alternator?
- 4.2 "Chuggles" at times.
- Recomended starter to buy
- Changed plugs….quite a difference.
- What 4.2L work in 1998 f-150
- 4.2 wont start
- speed limiter
- Realistic expectations from roller rockers
- CEL, on, off, on, off
- 2000 4.2 missing on #1 at idle
- Intermittent knocking
- bucking/hesitation 4.2l
- No spark at no. 2 & 6 cylinders
- 1997 F-150 4.2 surges when warm/ dies at idle
- 1999 f150 v6 4.2l code p0305
- 4.2 Parts source?
- Corrosion - beating a dead dog
- Red hot cat
- Is a 97 F150 4.2 internally or externally balanced?
- 97 4.2l Engine Replacement
- Cracked 4.2 coil pack.
- Need Help Water Leak on 4.2
- Popping sound when starting out
- 4.2 in 1997 f-150 backfiring while cranking...
- bank 2 lean code
- installing new camshaft sensor problem
- 4.2L V6 - Plugs, fuel filter and oil weight recommendation
- 4.2L interchangability?
