- Idle adjustment
- Fuel Filter
- Smoke on startup, Worry?
- low on power
- moisture in the motor oil
- Tell me about the 4.2L V6
- 4.2 miss at low rpm
- 4.2 litre intake gasket failure
- Intake manifold torque
- Need help, several codes!
- Dreaded Timing Cover Leak
- 3.8 vs 4.2
- CEL again
- New issue after motor replacement
- It's been a while
- 4.2 help pleease!!!!
- 1999 F-150 2WD 4.2 V6: Do You Use Motor Flush?
- 4.2 Leaking Lower Intake Manifold Gasket Question
- 2001 4.2L Exhaust Rattle at low speeds
- Intake Gaskets 4.2
- 2001 Ford 4.2L Coolant Sensor Issue
- trouble code help!
- 2002 4.2 f 150
- Has anyone tried this?
- Another V-6 collant leak
- Need more gears
- Drivers side engine lift bracket
- catalytic converter plugged
- po174 and losing coolant
- TSB 99-20-7 question
