- here are some pics of my truck
- i am a 14 and need someone to help me with my ford f-150
- 2001 f150 4.2 diesel sound
- recon engine 4.2
- I need a six speed or better that will bolt up to a 3.8
- OBDII Says missfire cyl.3
- 4.2L Belt tensioner
- tapping noise this morning in my F-150
- Code 542
- want power
- 96 3.8 windstar cyl 4 mis fire?
- Problems starting
- broken spark plug to cylinder misfire
- code 0175 bank 2 rich
- what are the stock camshaft specs.
- OBDII Help
- Cylinder head and rocker arm bolt torque specs
- Help with new motor
- 3.8 Bellhousing pattern
- Do 2003 4.2 have a pcv valve ?
- comments on v6 in new f150 please
- Q? for Brian,about your 05
- Fumoto drain valve?
- How do I find TDC on a 95 windstar 3.8L
- 300rpm?
- Engine code on E250
- Check Engine Codes....GGGGRRRRRR
- Knocking sound in rear when applying brakes.
- 4.2 timing adjustment
