- New Motor Question 4.2 Differnce
- 2Q's - Idle & A/C
- 4.2 still lean after extensive work, help!!!
- 4.2 skipping at low rpms
- 97 F-150 4.2L V6 Starting Issue
- Pulleys
- Question about plug wires...
- Transmission fluid change
- P0401, C1230, and finally, C1096
- Engine Lite On 4.2
- Transmission trouble
- Where is WOT relay on '01 f150 4.2L?
- Blue Devil head gasket in a bottle
- Need to replace 4.2. (Years/options?)
- 4.2L redline?
- 01' 4.2 f150 camshaft upgrade
- '01 F150 4.2L blowing fuse 23, multiple codes
- Changing coolant in '05 4.2L
- mass air flow sensor location
- When to change spark plugs/wires
- 4.2 double firing?
- 4.2L fireing order
- 2000 E-250 4.2 problems
- bad water pump or thermostat?
- 96,000 miles....
- Need to pick some minds
- Looking for vacuum leak
- 4.2L V-6 Hydrolocked and replaced
- 2000 f150 v6
- Octane.
