- #4 Cyl Coil on 5.4 V8 misfire via antifreeze
- 5.4L Valve knocking
- 4.2 to 5.4
- 5.4 excessive oil consumption
- 4.6 piston, valve tolerance
- 5.4 and 4.6
- OBD code PO174
- Vacuum Leak
- MAF removal ??
- Smoke coming out of exhaust when starting up.
- Why the hp low on the 4.6L
- 4.6L vs 4.6L
- Stroker Engine
- EGR Valve - How to replace?
- Not enough horses as I should have, HELP
- Anybody Done A Complete Buildup?
- rod journal size / specs??
- 4.6 spark plug options........
- 5.4 Misfire help!
- mass air flow sensor from 4.6L mustang gt
- 4.6L Oil Leak
- 4.6 info
- AEM Brute Force/ WMS Velocity Tube
- ATI Procharger
- Will a 2000 5.4L Upper Intake Bolt Up To a 1999 5.4L??
- timing on my 4.6
- Anyone use Evans NPG+ coolant?
- 4.6 question
- 5.4L and 4.6L Engine Dimension
- Oil Capacity for 2000 5.4 V8
