- flowmaster on supercrew cab
- Firing Order
- Picure of an 5.4L V8
- In shop- dealer give rental?
- Swappin the Air flow and such
- Cutting My Cats (Is this a good idea?)
- 5.4 performance ignition
- Starter Whine/Grind
- 1999 Ford F150 Spark Plug #4
- loosing oil
- Remove plug wires from plugs?
- Removing Convertor Screw 2001?
- '98 Eddie bauer Expediton 5.4L consuming oil prematurely?
- Engine swap opinions needed,4.6 or 5.0
- Spark Plug Blowout
- Cost From Dealer For Plug Replacement 5.4
- Dead spot in idle
- NEED HELP FAST - Replacement Plugs for 98 5.4L Expd
- 1994 F150 w/302V8 Idles too fast.
- Will a supercharger work with a power pully
- Red Anti-Freeze
- 4.6 Expedition??
- 2000 5.4L mods.
- Cooler Thermostat
- 5.4/4.6 oil consumption?
- Hello all, a friend needs some help
- vac leak
- Throttle body spacer
- help with fuel flow problem
- to root's or not to root's
