- Power Braking w/ a 4.6????
- where can you go to get the "codes" checked out?
- 97 Expedition 4.6L Misses and idles rough
- underdrive pulleys or 75mm throttle body
- Help!!
- plug boots, wow..
- 4.6 knock
- Maintenance to 5.4L
- Low Vacuum
- '02 F150 4.6L Engine Missing
- '99 5.4 pings
- build date
- Sounds like a cow
- dropping 4.2 for a 4.6
- Valve Train Noise 2001 F-150 4.6 4x4
- 4.6 Romeo
- 5.4 how far can i go with it ??
- modular intake fit other's?
- Will the 3V 5.4L get stronger with age?
- Engine Size
- 4.6 Gas Milage??
- thermostat question
- Blown plug, Heli-Coiled, Blown Heli-Coil, now replacing head
- 5.4L Idling High
- 4.6L V8 troubles
- po171 and 174 codes
- 5.4 problems
- misfire #4 cyl on the 4.6
- maintenance codes for 5.4l
- 4.6 oil burning
