- Possible engine build
- 5.4L making strange noises
- 2003 expedition with 4.6l aluminum block and heads
- To Seafoam or Not to Seafoam...
- What are the best plugs????
- 5.4 triton leak
- F150 missfire diagnostic
- Engine Stumbling and Getting Worse
- What Is The 5.4l Engine Made For
- ?? above front of Spare Tire
- 4.6/Tranny Q
- MPG - New 05 F-150 4.6L
- Rev limiter 5.4-litre 3v
- Big 5.4 problem - need help please!
- 4.6 compatibility?
- Engine Swap Help
- Cab air vents shutting off
- How to access plugs, some sort of keeper bar?
- best exhaust set up for a 5.4?
- timesert for blown plug
- 1995 4.6 Engine
- New Plugs and EGR Valve
- Code P1289 anyone had this yet?
- Newbi
- Blown out plug in Portland, OR
- Knock Sensor?
- Main bearing replacement
- Pcm Mounting
- 98 F-150
- Oil pressure problem continues after new sending unit
