- '97 E-150 with 4.6l fast idle problem
- 97 4.6 loading up
- Oil Leak Found (I think). Need Help - Pics Included
- Is it normal for the 5.4L to burn oil?
- 5.4, runs like bad c.o.p. or bad plug, no codes or pending
- Best Exhaust for 5.4L V8
- set cruise to rpm instead of mph??
- 4.6 Windsor flex plate?
- 5.4L Misfire - Noob Questions
- 4.6 L spark plug problem
- Oil filters
- What Coils go in my truck.
- Rough Start And Idle
- 05' 5.4 starting prob.
- Normal compression on 4.6?
- 2000 F-150 5.4L Misfiring
- whats the problem
- 2004 Ford F-150 spark plugs
- ive had it with this IAC valve
- 4.6 vibration
- 5.4 Coolant in Intake?
- '97 5.4 random oil leak
- will 07 5.4 fit in 04 5.4 f 150?
- 5.4 Compatibility - '05 to '99
- 5.4 into a 77 f100
- MotorCraft Spark Plugs
- Head gasket
- New member with several questions on 5.4L
- 5.4 freeze plugs
- 2001 idle racing
