- //SIMPLE\\ Best plugs for a 5.4
- Remove Fuel Rail To Get To Spark Plug & Ign Coil??
- throttle body spacer question
- Second time it won't start
- 2004 F350 5.4L engine into 2000 F350?
- I heads or not PI heads that is the question
- Proud new owner But...
- oil weight rec. for 5.4L
- How long will a 5.4L live?
- 4.6 intech to 5.4 parts interchange
- Need a progamer for 2 5.4s can it be done?
- Oil usage
- 4.6 humming noise and rough idle
- 2000 5.4 dying at idle
- 4.6 intake air temp sensor
- Vibration at Idle (revisit)
- How long does the 4.6 live?
- 4.6L vibration and rumbling at acceleration
- How do I increase Gas Milage
- milling after heads warped from overheating
- 4.6 head swap
- timing a 4.6
- How do I find Top Dead Center (TDC) on 4.6?
- 5.4 Bogging
- P0125 - Insufficient Coolant Temperature to enter Closed Loop.
- 4.6L problems loss of power, ticking
- How do I tell what 5.4 I have?
- In search for 300hp
- 5.4L Crate Engine Updates
- Define Modular
