- Hp?
- Block heater
- Cold start woes
- Holly Throttle Body?
- 5.4 cam swap?
- Gen2 K+N Air intake kit
- Connector hanging down
- EGR Valve Again?
- Squeal at start up
- P0304 and P0171 1999 Explorer
- bad noise/intermitant no oil pressure
- Ideal cruising RPM
- 4.6l taps on start up
- #4 misfire
- Trouble Code P0357
- 5.4L dies at speed
- fuel injector wire missing need HELP!! ASAP!
- Anything else?
- runs cold
- Sticking Idle
- 4.6 head vs 5.4 head
- Hunting misfire, need a little AutoTap help.
- Any improvments to the 4.6 from 97 to 2004?
- cold starting
- 5.4L exhaust leak, lean/rich fuel mixture
- 5.4 3v and/or2v??
- weak coil pack
- engine vibration
- Question about plug blowout...I know, I know
- which 4.6L in my 2001 Exp
