- 5.4L Possible Service
- another missfire ?
- 5.4 L misfire at operating temp.
- 5.4 Cams
- #3 coil pack
- looking for an extra honing torque plate for 4.6
- Better heads
- firing order
- Low Fuel Pressure = Miss ?
- 5.4L Shudders under load/rough idle
- Coolant in Oil Sump, any ideas?
- 5.4L What changed between 98 & 99??
- 98 5.4L More power for street and towing
- 4.6 to 5.4
- the "other" coolant caused misfire?!?!
- P0420 (what is it?)
- Looking at 04 6.0 CC 4x4
- Pcv
- code PO300 and a PO307
- Exhaust Work
- Axle Ratio Change - 4.6L Expedition used for towing
- 4.6L Noise...
- help
- valve job
- Missing Under Load - Bucking
- extended cranking intermittently
- bad coil pack
- Where are the "copper" marks on my timing chains?
- Flashing Check Engine Light
- Skunk Farts?
