- 4.6L Block Markings
- CV 4.6 throttle plate problem-any fixes?
- Cam shaft torque specs
- More performance opinions
- Trans problem??
- 1998 f-150 4.6L over to a 2002 f-250 5.4L
- 5.4 VSS and O2 sensors question
- 2000 4.6 runs rough engine light off?
- running lean?
- Whats spark plugs to use?
- expedition with 4.6 power question
- Lightning Supercharger interchangability
- Torque peak/rpm range
- how to change coil pac in 99 F150
- 5.4 procharged/vortech?
- How to clean fuel injectors
- 99 5.4 on E-85
- 97 4.6L - Turning the Crank by hand
- Please help with spark plug location.
- How does a stock 4.6 hold up to nitrous?
- Rough idle 600 rpm in drive
- My first Ford nightmare
- pcv and oil consumption
- 4.6L with cold air tube makeing "thunk" noise
- Removing the Cat...
- 2002 5.4 needs more power.
- "CHARGE" IT
- 5.4 Head Removal/Time-Cert Install
- Modulars In Older Trucks
- What have I got?
