- valve spring help
- Bad battery???????
- P1744 code and sugestions
- More blown plug questions
- No Codes
- Check engine and OD light flashes at same time
- Need 4.6 to 5.4 interchangability for my 1994 F150 swap!
- not a5.4 miss
- Romeo 4.6 tick (TSB 03256)--timebomb?
- Another 5.4 sounding off
- check out this mod for the f250 5.4's
- Electrical terminals
- Help me make my 05 louder
- 5.4 misfire and codes
- CoPs? Wires? PCM Connections? Cursed?
- 05 or newer 5.4 with gears
- OBDII scanner Cylinder 8 Misfire
- ERG Valve
- supercharging a 4.6
- Plug #4 and coil
- my 4.6L has a rattle
- Throttle sticks when coming off of idle
- 99 expy 5.4L intermittent oil pressure
- 5.4 ignition problem
- Wash my engine ???
- 5.4 misfire
- 2006 5.4 5w20 oil?
- 2001 Expd 5.4L - low vacuum after head replacement
- flashpaq for 2006 f250 5.4l
- 2000 5.4 triton
