- 5.4L Minor problem or Major Problem!
- engine swap
- Won't start after air filter change
- Fuel Efficient 4.6 L Rebuild Help
- 99 expedition engine trouble
- Exhaust Manifold Studs
- old tach pin 48 pink and white question
- Idle all jacked up
- Is there an easy way to check for spark?
- 7.3L Guy w/ 5.4 Sparkplug ?'s
- Will Someone Please Post A Picture For Me...
- oil additives
- need help here asap!!! blown plug and other problems!!
- 4.6L air intake box????????????????????
- New starter motor noise? advice asap!
- 5.4L Engine ticking (NOT cold knock)
- oil drain plug
- Hi-Po Heads
- 5.4 spark plug repair
- Best 5.4l programmer?
- My 4.6L spun a rod bearing, help!!!!
- 4.6 tapping briefly
- po171,174 intermittent,5.4,1999
- 4.6 bolt pattern
- Octane Boost Additives
- 5.4 Engine stumble and no code
- 01 4.6 TB upgrade
- 5.4 plug repair kit available
- new heads?
- 99 E150 #2 #8 Misfire
