- Question about the blocks used in 5.4 triton
- 4.6 Tune up
- When do you need to change the timing chains on a 5.4?
- No Problems With My 5.4 Motor
- check engine light (HELP)
- 98 4.6l misfire
- good 'ol 5.4L....
- how hard is it to change plugs?
- 5w20 vs 5w30
- Code po136 & 156 on 98 F150 4.6
- Coil On Plug (COP) Testing
- 4.6 liter blues
- oil flow
- Mod motors
- crown victoria no start (4.6)
- 5.4L Noise on start-p
- replacing coil bolts 98 5.4l
- Why does my 03 5.4 SD smoke
- 5.4 Massive Oil consumption
- Can you tune a pretty stock truck?
- Hot vs. Cold spark plugs
- 5.4 timing chain replacement interval
- Oil Filter ?
- spark plug problems
- How long to run with belt off
- 02' 5.4 poor performance
- going crazy
- Modular Engine Website
- No Compression
- 4.6 Triton V8 misfire
