- 02 EXPY AWD 5.4L loss of performance above 95 degrees outside temp
- 5.4l timing chain tensioner issue??
- 5.4 heads question
- No PS or brakes on 4.6
- oil in piston chamber
- 2002 F250 5.4 Won't Start after plug repair
- Help with dtc P0304
- sparkplug coils
- Problems with a 98 5.4L
- free mods
- 5.4 motor question
- Can you upgrade a 4.6 NPI to PI ?
- Help !!!!!!!!!!!!!!!!!
- 5.4 Oil Cooler Adventures
- 5.4L Roars on Start Up
- 5.4 coolant leak/intake problem ? HELP !!
- 4.6 engine codes
- '97 E-150 with 4.6l fast idle problem
- 97 4.6 loading up
- Oil Leak Found (I think). Need Help - Pics Included
- Is it normal for the 5.4L to burn oil?
- 5.4, runs like bad c.o.p. or bad plug, no codes or pending
- Best Exhaust for 5.4L V8
- set cruise to rpm instead of mph??
- 4.6 Windsor flex plate?
- 5.4L Misfire - Noob Questions
- 4.6 L spark plug problem
- Oil filters
- What Coils go in my truck.
- Rough Start And Idle
