- Supercharger HP loss?
- 87 302 efi with no compression in 4 holes?
- HOW TO SWITCH FROM 5.0 EFI TO 5.8 EFI????????
- Throttle Body Spacer and FIPK
- What to get next
- f150 4x4 with a 302efi
- 351 oil filter stud removal?
- Is the MSD Rich/Lean indicator any good?
- Check engine light!!!
- rebuilding 351-w
- Supercharger on Stock EFI 302?
- K&N and Air mass sensor
- MSD Ignition
- K&N FIPK!!
- Anyone ever found a thrust plate in the bottom of their oil pan?
- Spark Plug reading
- BSFC and Exhaust Gas Temps (EGT) Info
- Damaged Threads
- 2.9 build
- Oil Pressure Sending Unit
- Sidegapping?
- Long block sources
- Installing ignition MSD 6AL, Easy or Hard?
- 302 knock
- 347 Stroker? 351? Supercharger? for Laforza w/ Ford 302 that needs rebuilding
- Hood scoops and the weather
- exhuast
- replacing front cam seal on 96 F-150, V-8
- 383-430 cid
- More air
