- comp Xtreme 4x4 cam
- Does boring an engine change compression ratio?
- From across the Pond
- Sniper Tuners
- How would you build a 351W?
- gas mileage and hp
- Big cam on 460
- Using a Non-contact thermometer for diag.
- 514 Timing Questions
- 5.4 cam timming
- 460 maximum power
- Fuel Injected 5.0; Dismantle in Progress; Opinions/Advice Wanted
- Simple bolt ons for torque?
- safe limits on a 351W
- Need help w/ parts for 302 build, & casting # help ??????????
- distributor timing, cam, timing chain ??'s
- Best stock heads for racing
- camshaft, lobe, compression
- intake porting just a question
- Gasket sealants
- Used roller rockers?
- fe 390 questions
- Ford 302 build first timer
- Mods for milage ?
- Getting frustrated with 5.0 Need advice
- adjustable rocker arms
- Starting a new project
- genous or insanity....probibly insanity.
- Glowing White Hot Headers
- OK to Modify or Should I Rebuild?
