- 302 long rod
- Engine Rebuild
- stroking
- Unidetified Ford Object
- DP carbs with automatics
- Timing marks jumping around too much - can't set timing
- where the fuel fliter located
- Gas/Diesel Engines, but not the question you expect...
- TDC 351W
- Advancing cam
- Hot start problems
- Aftermarket Programmable EFI on a 460?
- Fuel economy/ Gas mileage
- Engine performance
- 89 intake on an 85 motor
- B&M shiftPlus electronic shift Kit
- something new but kinda a pricey
- Ram Air Electric Superchargers!?
- 302 + 351w heads
- Ignition Timing Advance
- Exhaust Injection System
- Underdrive Pulley Replacement
- fuel injected vs. regular carborator / swap ??????
- Hardened valve seats??
- Bore info?
- 1999 F-150 4x4 4.6 Enhancements?
- Timing Gears
- Tachometer and Crane HI6 question...
- recurving dist.
- Making a 302 a 347.
