- Spark plug heat range
- Compression vs heads & fuel needs
- 73 302 with low compression ratio
- Great Book on Ford engine building.
- 393 stroker build questions-block machine work
- cylinder head question
- 5.0L f150 heads
- 351 performance
- Wanting to build a 351w with 300 to 400 hp
- I found the water jacket, it in this hole i made
- mass air 460
- E7TE head porting
- singh grooves in cylinder heads?
- cleveland and winsor
- High Idle Concern
- Solid Motor mounts
- new carb and intake issues
- Cam Selection???
- Clean up required after replacing main bearings
- easy performance upgrades on a 351W
- Ignition Problem ?
- 351W Camshaft Choices
- 300 4.9 Lifter Tap
- E van 5.0 intakes?
- Crrank shaft Question
- what would installing a 390 Crank get me???
- Pulstar pulse plugs...whats your take?
- Now that I have an option....which engine?
- Tore into My Engine, Found a Surprise
- 302 Rebuild Questions Out The Wazoo
