- E89e-6015-ad
- heating problem
- 460EFI cam / CR questions
- Where to get a good gasket set for 460EFI?
- True Trac/4.10
- 2.8 V6 conversion
- Whats a good oil filter?
- exhaust and emmisions
- 460EFI questions, maf, wise or not?
- What heads work w/ stock pistons?
- Piston ring gap
- What special tools needed for engine assembly?
- 460EFI firing order, and tri-Y exhaust Q.
- 1`st time at the drags tonight
- Where do you start?
- Has anyone else used an ARP fastener kit?
- 289 Rebuild Questions
- ??? about advancing cam
- nos on a future build.
- Tornado`s
- 351 power/torque increase suggestings...
- 94 F-150 351 rebuild with lightning parts?
- Aspects of distributor timing
- Initial timing on '89 302
- Ball and Socket Headers
- 302/351W same oil pump??
- 351w crank offset ground to 3.7 stroke
- Your suggestions... motor/tranny/transfer case
- what forum do you put this in???
- Accurately timing by balancer??
