- can anyone answer this.....
- Does higher compression mean better mpgs.
- 408 SuperCarged photos in gallery now!
- Need Help! Custom Mass Air Not...
- porting and polishing
- Comp cams retro roller
- Best performance for the dollar/ '92 460
- building a 460 EFI engine to get over 500 hp
- Flow matched injector source??
- cam lobes not smooth
- piston to valve clearance
- High compression vs. low compression.
- another intake question
- New Valve System
- more acceleration
- my 302 h.o. is stalling when it's washed
- 92 300
- smokin' 460
- 460 timing
- Carbon removal
- e40d, transfer case etc strength.....427 windsor???
- fluid type damper?
- 351m/400 rebuild
- 2.5L tinny ping/
- headers
- Turbo for 5.0L-- is there?????
- Valve Tap
- Why does it smoke?
- engine shutdown
- 302-351W crank
