- '82 F150 302 rebuild
- When to rebuild 2.3?
- yay, kept it under 200 degrees 0.60 over 302
- traction problems
- Drag Time improvement
- What cam size?
- starts hard when hot-help!
- Rebuilt Advice
- Performer 289 Help Plz
- 87 ford 302 torque specs for main cap
- Upper Intake
- 460 Build up plz help
- crank oil slinger? huh
- F150 5.0 intake manifold
- Need help with a 302 project.
- EGR, Performer Carb, and the 351W
- Need more power from a 351
- i need advice on mustang 5.0 to f-150 5.0
- 1987 ford 302 truck motor
- 351w oil pump?
- 351w piston location?
- ignition system choices
- Propane Powered Engine questions
- Cheap 302efi builds..HELP!!
- Head and Intake Gasket Orientation
- Intake porting
- Will it fit?
- Low compression in #4 & #8. time to start rebuild list.
- What should i do!
- Ignition upgrade ????
