- Torque Camshaft / RV Camshaft
- Open Headers in the winter???
- Ever heard of a Linclon 430 motor?
- Favorite Plug Wires?
- "Test" Pipes
- Air intake Mod ?
- motor a little tight after putting crank and bearings in but good clearances.
- 351 M head suggestion
- graphite head gasket ?
- difference in hydraulic flat and roller cam?
- which motor, need advise
- what motor to go with
- 351m or 302
- Cold air intake or Stock replacement filter
- Hone: flex or 3-leg?
- breath deeply 2
- engine analyzer v3.2 Ddyno
- Mass Air Flow vs. Speed Density
- cast vs moly rings???
- Cam*bearing install tool
- Throttle body spacer - worth the money?
- Chassis Dyno Cost?
- Total Seal piston rings
- BBK 75mm Throttle Body Any Good?
- Redneck hot tank - what chemicals needed?
- Speed Density Question
- do i need mass air?
- Smog Head Porting
- Sealed Power BEFORE Federal-Mogul
- Idea: Real Cold Air Intake
