- Vacuum Leak
- What Year
- STD VS High Volume
- wanting to port
- first time 351W build
- how bigger parts affect low end torque
- good (9.5-10) compression+big load=detonation?
- help f250 99 V10
- Which Engine Should I build up?
- Head gasket question
- need opinions
- engine build
- comp Xtreme 4x4 cam
- Does boring an engine change compression ratio?
- From across the Pond
- Sniper Tuners
- How would you build a 351W?
- gas mileage and hp
- Big cam on 460
- Using a Non-contact thermometer for diag.
- 514 Timing Questions
- 5.4 cam timming
- 460 maximum power
- Fuel Injected 5.0; Dismantle in Progress; Opinions/Advice Wanted
- Simple bolt ons for torque?
- safe limits on a 351W
- Need help w/ parts for 302 build, & casting # help ??????????
- distributor timing, cam, timing chain ??'s
- Best stock heads for racing
- camshaft, lobe, compression
