- 289 vs 302
- Which Edelbrock cam would be best?
- 351c specs
- all info on a 300 I6 to 460 engine swap
- crankshaft question
- Do spacer blocks help performance?
- Octane Rod Mod?
- How much CFM . . . .
- Are Hyrdraulic Roller lifters any good?
- Anyone using gasket selant on intake manifold?
- marine blocks
- Rebuild
- 393 stroker kits
- Which Plugs to Use??
- what jets?
- Engine swap
- Engien weights
- 302 long rod
- Engine Rebuild
- stroking
- Unidetified Ford Object
- DP carbs with automatics
- Timing marks jumping around too much - can't set timing
- where the fuel fliter located
- Gas/Diesel Engines, but not the question you expect...
- TDC 351W
- Advancing cam
- Hot start problems
- Aftermarket Programmable EFI on a 460?
- Fuel economy/ Gas mileage
