- Emissions testing woes 76 460 in AZ
- straight 6
- Can I have some opinions... Output shaft ZF5.
- Noisy steering
- Handbrake / Parking brake
- looking for budget 460 torque recipes and builds.
- Hydroboost question
- Canada VIN Decode
- Back pressure through cooling system???
- WTF? Intake Manifold Port?
- Glovebox door
- Repair mirror mounting points.
- Is your Low MPG caused by no vacuum advance ???!!!
- 79 f150 4.9 1bbl idles like crap
- Vin # question
- Junkyard Driveshaft?
- Distributor wiring
- Tail light wiring issue
- 351M Oil Pressure
- Timing Advice
- Fuel sending unit
- Need suggestions please, truck will barely run- UPDATE, FOUND PROBLEM
- At wits end: Runs great, no power on hills/4th gear
- No tailights no turn signals brakelights work headlights and front turnsignals flash
- very brief rod or bearing knock only on startup?
- The nut in the engine compartment
- 460 Engine Block Heater
- Is my 460 overheating because I'm missing the water pump backing plate?
- No harmony in my harmonic balancer
- [Transmission] C6 w/4WD
